Sidan 7 av 8 FörstaFörsta ... 5678 SistaSista
Resultat 121 till 140 av 148
Ämne: Custombilder
  1. #121
  2. #122
  3. #123
  4. #124
  5. #125
    Utanför landskrona
    1 539
    Tackad: 7
  6. #126
  7. #127
    1979 FLH Swalllowtail
    Handmade organic shape has produced mature shiny shovel in total 79 shovel to the concept of drag racer, set a 19/15 inch wheels front and rear genuine skeletal frame. HOOSIER logo on the rear will be the accent. Point in the exterior of aluminum, except for the tank is made of one-off. As the word "was difficult is that you can use to create a new sheet metal molding," says, from organic shape is impossible without a trace of pain is only in handmade probably suggests to. Thing to see a solid paint work to highlight and maximize the texture of each part. Black out the primary cover and tightening around the legs, such as wheel rims, the tank and select a color matte. The height of the machine's shiny perfection in total.Triumph of the front brake into the "mesh" There is a tree, stretched mesh in the tank was manufactured with an aluminum air duct, Tsusuroto to select the cab. That are linked in three places by this mesh design. Also one-off production in the triple tree to the bar of one-off and swallow. Reasonable control by the mid-position, easy to form a riding position fit, such as the main cut.
  8. #128
  9. #129
    Harley-Davidson of Pavia.
    HD Pavia has been creating some very atypical Harley customs over the years. Unique creations, all of their bikes manage to remain "Harley" while offering their owners some very current ideas rather than the usual chrome and skull treatment. www.harleydavidsonpavia.com
  10. #130
    Satans feta åk i den här tråden! Jag känner att det bara kliar i fingrarna och att ett garage måste inskaffas!
    Efter att ha surfat lite chopcult känner jag att jag måste uppa några bilder också...
Namn:	Untitled-1.jpg
Visningar:	147
Storlek:	77,1 KB
Id:	7358Klicka på bilden för en större version.
Namn:	Untitled-2.jpg
Visningar:	145
Storlek:	54,5 KB
Id:	7359Klicka på bilden för en större version.
Namn:	4773589341_364892f69a_b.jpg
Visningar:	137
Storlek:	62,9 KB
Id:	7360Klicka på bilden för en större version.
Namn:	d.jpg
Visningar:	143
Storlek:	98,5 KB
    Frågan är om man ska satsa på shovel eller sportster...eller evo...
    Köpa en gammal byk-hoj och slakta eller köra som admin -modellen där man samlar delar...? =)
    Känns som att stelbensram och sportstertank är min melodi iaf...hehe
  11. #131
  12. #132
    Tyckte attt min budget hoj passade bra här, så ni får ursäkta, jag lägger ut den...
    /R
  13. #133
  14. #134
  15. #135
    Citat Ursprungligen postat av Rolf Axel Scootsandbikes Visa inlägg
    /R
    Det gör den helt klart!
  16. #136
  17. #137
  18. #138
  19. #139
  20. #140
    Yeeea vart e alla svensk choppers me gaffellängd på minst 12tum över m sportytank å stroker puffra,late 70 tidigt 80talare.När strutshoveln börjar bli sällsynt å panheads e minnen bara.D är då jag undrar,har jag blivit gammal.
  1. Lite mixade custombilder från Frankrike!
    Senaste inlägg: 2011-06-15, 22:10
