With master cylinder (M/C) cap on: First disconnect upper brake line from ABS module, very little fluid will drip, but have a rag ready. Put open end of that line into a container, remove M/C cap and drain M/C. Disconnect banjo at M/C... be ready for remaining Dot 4 to drain into container and drip at banjo. Connect new brake line.
For Reverse Bleed you'll need clear tube 3/16" ID (5/16" OD) from Lowes or Home Depot, I used 4'. And you'll need something to push Dot 4 through the clear tube into the bleeder valve... I used a syringe (no needle needed) I'd gotten from Granger, the clear tube will screw onto the syringe. (I read of someone making a squeeze bottle; Plastic Coke bottle with a 3/16" nipple attached to the cap, and a breather hole on the bottom).
Heat one end of the clear tube and slipping over the bleeder valve nipple, this will make a good fit. Remove clear tube from nip. Full your syringe by sucking dot 4 into it, attach clear tube to syringe and FULL clear tube keeping open end higher then syringe so all air is removed. Attach clear tube to bleeder valve nip. Now hold syringe high and check clear tube for any air bubbles, if any, allow them to float up to the syringe (tapping the tube will help move them along.
Open bleeder valve and inject dot 4. if you need to refill syringe, close the bleeder valve... unscrew the syringe (keeping open end of clear tube high)... suck more dot 4 into syringe... attach clear tube... tap out any air from the clear tube... inject...
Keep an eye on M/C for dot 4 entering. Fluid will have foamy air bubbles at first, continue injecting until no more bubbles... you may need to remove some dot 4 from M/C to avoid overflow (I used syringe to suck some out).
Tip: Before injecting; Position your new brake line so fluid has a continuous up-hill climb to M/C, as down dips in the line could trap air. I also manipulated the new brake line once filled; working from ABS module moving upwards... I'd create steeper angles and tap the line to move along any bubbles that possible clung-on.
That's it. Easy. No mess. Took less then 1 hour.
