Tack för info,men vart sitter den,så fort jag jag kör på höga varv blinkar lampan på instrumentet man blir mat...
Hej ock tack, du vart sitter den har kollat under sadeln,och nu har lampan på instrumentet börja att blinka men kör man inte på höga varv så slutar den att blinka blir helt mat av blink problem...
Hittade ett kopplingsschema för TSM/TSSM : http://www.craigwolford.com/04%20SOFTAIL/se03a.pdf
Den ska sitta här enligt denna beskrivning.
Located behind the plastic splash panel in front of the rear wheel (just below the front edge of the rear fender). The panel is held in place by two bolts near the bottom edge, just in front of the wheel. The top is held on place by a notch that fits over a tab on the frame. Once the splash panel is removed, the module is clipped in place sideways about half way up.
Hittade en dassig bild.
En till, nummer 5.
Bildtext.
See Figure 8-3. All Sohail models use a panel under the rearpanel contains:
fender to mount important electrical components.This electrical
• Vehicle speed sensor:VSS (3) (651.slot in transmission case.
• Turn signal module (TSM) or turn signal security module
(TSSM) and connector (5) [30].
• Master circuit breaker (2).
• Security siren connector (6) (142).
Use the following removal and installation information to service
electrical panelcomponents.
REMOVAL
1. Removeseat.
AWARNING
To prevent accidental vehicle start-up, which could
cause death or serious injury, disconnect negative (-)
ballery cable before proceeding. (00048a)
2. Disconnect negative batte ry cable.
3. Remove right side saddlebag if present.
8.4
NOTE
Rear wheel may have to be raised slightly to allow for inner
fender removal.
4. See Figure 8-5. Remove two bolts (1) from rear inner
fender. Bend upper right corner of fender towards rear
tire and lift upward to clear hole in fender (2) from tab on
rear fork (3).
5. See Figure 8-3. Remove circuit breaker (2), speedometer
sensor (3), turn signal/turn signal security module (5)
and vapor valve (7) from tabs in electrical panel.
NOTE
If securitysiren is not installed, remove securitysiren connector
[142J from receptacle in electrical panel.
6. If installed, remove security siren (6) from tabs in electrical
panel.
7. On California models, remove canister tubing from electrical
panel.
8. Cut electrica l panel cable strap (4).
9. Remove electrical pane l fasteners (1) and remove electrical
panel by disengaging tab at bottom of panel from
Hej! Tack för all info och hjälp nu funkar blinker fattas bara larm tricket nu med en eq, felet var att kabelskon från batteriet + skavde mot kabelhärvan på vänster sida och brun kabel så därför bran eq upp,så nu är det fixat det tog en dag men nu går Natt tåget som tåget och blinka bra gör det Tack så himla mycket för info ett bra forum folk förstår mycket här... Hoppas det hjälper någon fler.
Senast redigerat av harly2006 den 2012-05-18 klockan 21:47.
tackar för svar, fick svar från badland och tydligen var det fel load equalizer jag hade så nu med den nya funkar det bättre dock så vart det jävligt trångt för original modulen ska sitta kvar också, inte så generöst med plats under sadeln...
Japp nu funkar larm icon som den ska,eq custom crome 2 tre kablar svart,lila,brun löd in dom på plinten under sadel på motsvarande färg från plinten då funkar det ales bra, har en NT 2006 med orginal larm.
Bra jobbat! Skam den som ger sig
Japp ger man sig ska man nog köpa en ny moped....
