Hela listan för Dyna 2007: (lite halvtaskig översättning från tyska)
Dyna Torque Streetbob 2007
Assembly Handlebar / Fork
Upper and lower light switch housing from 3.9 to 5.1 Nm
Handlebar clamp clutch lever from 6.8 to 9.0 Nm
Handlebar clamp HBZ 6.8 to 9.0 Nm
Lower triple clamp bolts from 40.7 to 47.5 Nm
Upper triple clamp bolts from 40.7 to 47.5 Nm
Axis Cap Fasteners -19.0 13.6 Nm
Handlebar clamp (riser cover) from 16.3 to 24.4 Nm
Lower handlebar clamp mounting parts from 40.7 to 54.2 Nm
Headlight adjustment screws for 33.9 to 40.7 Nm
Brake assembly
Brake caliper bleeder valve from 9.0 to 11.3 Nm
Brake pad retaining pins from 20.3 to 22.6 Nm
Front brake caliper mounting bolts from 38.0 to 51.5 Nm
Befestigunsmutter brake caliper from 40.7 to 54.2 Nm
Brake master cylinder cover 0.7 to 0.9 Nm
Front brake disc screws from 21.7 to 32.5 Nm
Rear brake disc bolts from 40.7 to 61.0 Nm
Banjo (banjo) from 23.0 to 29.8 Nm
Rear brake light switch from 16.3 to 20.3 Nm
Chassis assembly
Upper shock absorber bolts from 101.7 to 115.2 Nm
Lower shock bolt from 40.7 to 54.2 Nm
Front fender mounting nuts from 20.3 to 28.5 Nm
Rear fender bolts from 16.3 to 24.4 Nm
Front axle nut from 67.8 to 74.6 Nm
Rear axle hub nut from 124.7 to 132.9 Nm
Fastener rear turn signals from 16.3 to 21.7 Nm
Fußrastenhalterungsschrauben 33.9 to 47.5 Nm
Assembly motor / gearbox
Engine oil drain plug for 19.0 to 28.5 Nm
Drain plug for Primäkettengehäuse 19.0 to 28.5 Nm
Gear lubricant drain plug from 19.0 to 28.5 Nm
Clutch inspection cover from 9.5 to 12.2 Nm
Primary cover screws from 12.2 to 13.6 Nm
Kupplungsausrückdeckel 9.5 to 12.2 Nm
Kipphebeldeckelschrauben 20.3 to 24.4 Nm
Crankcase bolts from 20.3 to 25.8 Nm
Cam cover bolts 14.1 -17.5 Nm
Oil pressure switch from 10.9 to 16.2 Nm
Neutral switch from 13.6 to 20.3 Nm
Air filter cover from 4.1 to 6.8 Nm
Fuel tank mounting bolts from 13.6 to 24.4 Nm
Lambda probes from 39.3 to 59.7 Nm
Flange on the cylinder head / manifold from 6.8 to 9.0 Nm
Heritage occasion consolidation screws from 17.6 to 27.1 Nm
Anlasserpluspolmutter 7.3 to 9.6 Nm
Spark from 16.3 to 24.4 Nm
Batteriepolschrauben 6.8 to 10.9 Nm
Pulley bolts from 74.6 to 88.1 Nm
Dash mounting screws 2.0 to 2.7 Nm
Attention!
Some bolts (cam covers, cylinder head, etc.) is a tightening sequence to
! note
All figures refer to the model year 2007 and are no guarantee of course! :-)
I assume no liability for any damage!
