Behövs något mer till Flake buster eller är det bara att koppla in till kompressor.
Har du nått bra tips på var man köper miniflakes?
Är nybörjare i ämnet men intresserad att ev testa på ena bågen i garaget.
/Rolf Axel
Oljetank helt i RostFritt syrafast utan tanklock
265mm lång
154mm diameter
opolerad men kan fås högglanspolerad + 200kr
Följande är oanvänt och i originalförpackning !!!
MINI FLAKE BUSTER WITH IWA4200 6-1/2OZ FLAKE COLORS 2 BOTTLES
Item Number: OSF KIT-MFB-IWA4200
Your Price: 317.57 (KT)
Quantity On Hand: 12 (KT)
Qty
• Worlds only dry metalflake gun specifically for use with an airbrush.
• Uses Patented Method and Design.
• CNC Billet Aluminum sprayer.
• Color coded Nylon inserts fit most all airbrushes.
• Works with siphon or gravity fed airbrushes and won’t harm the surface.
Mini Flake Buster with IWA4200, 6-1/2 oz. Flake Colors and 2 Bottles
Instead of the conventional method of mixing the flakes in a liquid vehicle such as clear coat, the Mini Flake Buster actually blows flakes onto the wet clear in a dry form, giving the user much more control over the flakes being applied.
Part# OSF FBV-01
Bustin Flake DVD
BUSTIN FLAKE DVD shows hands on, in-depth how-to of using the World Famous Flake Buster by Old School Flake. This is a must have item for anyone that currently owns a Flake Buster or for those interested in really saving time and making money doing metal flake paint jobs. This new DVD shows proper techniques such as adjusting the Flake Buster for correct air pressure, application distances and correct coverage amounts.
It also covers items like prepping for clear coat, laying out flame jobs with flake, custom tints and fades with candies and many special tips and tricks. This DVD is sure to help make your flake job a raging success whether it's your first one or simply your next one in line.
Features:
Interview with Rikk Clark, Inventor of the Flake Buster
Flake Buster Overview
Air Pressure Guidlines & recommendations
Proper Prep of Substrate
Ground Coat Suggestions
Proper Cleaning Techniques
Important Safety Issues
Spraygun Settings
Flake Buster Settings
Flake Application
Clearcoating tips for burying flakes
Tapeout application
Applying custom designs
Custom Fading/Edging effects
Leveling flakes for smooth coating
Candy/Flake application tips
Design suggestions
Full Coverage vs partial coverage
Ordering information
Clearcoat/Wet bed application
Oljetank 1500kr eller högstbjudande ( +200 högglanspolerad )
Flakekit + Dvd 2500 kr eller högstbjudande
Sissy 250kr
Senast redigerat av Lillan den 2013-11-11 klockan 18:57. Anledning: fel
/Rolf Axel
Flakes i olika former och även kandy har jag köpt flera gånger från hotrodswede.se.. Bra att handla av och billig! Inte världens flashigaste hemsida men vad gör väl det Produkterna på funkat kanon, jag såg/kände ingen skillnad mot kandyn jag köpt tidigare på nordicflake.se och dom är bra mycket dyrare! Kan väl tillägga om du ska köpa kandy så satsa på våtkandy kmkoncentrat.. Pulver kandyn blir mer som en Pearl..
Skall kolla in sidan men tyckte inte jag riktigt fick svar på min fråga dessvärre.
Behöver jag köpa något annat än material, grundfärg, klarlack och flake för att börja lackera?
Jag har en stor kompressor.
Tacksam för svar.
/R
Hej , du behöver ju måla sakerna i lämplig bottenfärg (svart brukar funka bra), klarlack som används som "lim"
Därefter blåsa på flakesen torr och bättra på med klarlack efter behov , när ytan är täckt kan man trycka ned de
Flakesen som står upp och sedan lägga minst 2-3 lager med klarlack som får torka helt och hållet . Därefter slipning
utan att gå igenom till flakesen . Klarlacka igen och ev mellanslipa och klarlacka igen vid behov.
Jag tror att du behöver en Airbrush.
http://www.tipro.se/sv/info/house-of-kolor.html har bra sortiment från House of Kolor.
http://www.ebay.com/itm/FLAKE-BUSTER...792687&vxp=mtr
Kan funka med en luftspruta istället för airbrush som ingår i sådana där billiga kompressorkits , men jag vet inte säkert om den passar.
vad funkar bäst då? Torrspruta flake eller blanda ihop det med klarlack? förutsatt att man har en spruta som klarar det dvs..
Trägen vinner!
Att spruta flake uppblandat med klarlack kan vara väldigt besvärligt om man vill att flakesen skall täcka ytan helt ! ( och det vill man ju ). Detta pga den stora mängd klarlack som följer med när man sprutar med så stort munstycke . ( 1,5 -3,0 ber. På storlek på flakesen). Bättre då att använda färglös bas ( binder) eller någon annan klarlack som tillåter att man inte behöver vänta 10-15 min mellan lagren. Så att blåsa på flakesen torrt med klarlack som lim är helt klart en intressant metod som jag själv skall prova den närmaste tiden !
Är ju ganska kul att köra old school och strö Flakes med saltkar! microflakesen på hotrodswede funkar riktigt bra att blanda i klarlacken, men den blir mer glittrig än flakig
Du har PM!
