Därför att denna CVO-motorn troligtvis är en gummiupphängd 110A-motor(framgår inte av texten).
Och passar därför bara till övriga HD-modeller, utom softail.
Softail:en ska ha 110B-motorn med balansaxlar i stället, och utan gummiupphängning.
Bring your T win Cam motorcycle up to the same displacement
and power output as the CVO™ S creamin’ E agle® models – a
gigantic 1800cc’s. T his street legal kit combines all the proven
components of the CVO S creamin’ E agle models – the 4"
Big-Bore forged pistons and cylinders, SE -255 camshafts,
and cylinder heads with automatic compression release. T he
Screamin’ E agle cylinder heads and forged piston combination
offers a 9.3:1 compression ratio for easy starting.
The cylinder heads also prominently feature the “Screamin’
Eagle 110 medallion. Kit includes all required gaskets (except
primary cover and transmission interface gasket) an d hardware
to complete the installation. I nstallation requires case
boring. Professional installation recommended. S eparate
purchase of cam spacers is recommended. R equires separate
purchase of appropriate Automatic Compression
Release Wiring Harness. All E FI-equipped models require
ECM calibration* (priced separately).
27501-10A Black Highlighted. $1,675.95
Fits 50-state ’10-later T ouring models (except T rike). Kit
includes CVO Air Cleaner Back Plate. ’10 FLHX and FLTR X
models require separate purchase of 2-into-2 Head Pipe Kit
and Mufflers. ’11-later T ouring models require installation of
CVO Mufflers P/N 64768-09A and 64769-09A or
FatShotz Muffler Kit P/N 80847-10 (sold separately).
27508-11 Black Highlighted. $1,675.95
Fits ’11-later Softail® models (except FLS , FLSTN and
FLSTS B). Requires separate purchase of Screamin’ Eagle
high flow air cleaner and ACR Harness P/N 70623-11.
27505-10A Black Highlighted. $1,849.95
Fits 50-state ’11-later Dyna® models equipped with Shorty
Dual Exhaust. Installation requires separate purchase of
Muffler P/N 64895-10 (Qty. 2). Fits 50-state ’10-later
FXDF and FXDWG models. Requires separate purchase of
Mufflers P/N 65884-09 and 65886-09. Kit includes
chrome Heavy Breather Air Cleaner Kit.
29866-07B Black Highlighted. $1,995.95
Fits ’07-later HDI T ouring models, ’07-’09 HDI Dyna models,
and ’07-’09 HDI FLST F and ’07 HDI FXST D Softail models.
Street legal on HDI-configured models when installed with
Original Equipment air cleaner and exhaust. ’11-later T ouring
models require separate purchase of Ventilator Air Cleaner
and CVO mufflers P/N 64768-09A and 64769-09A.
Är inte alla Softail med balansaxel? Jag klippte ur texten ur catalogen i USA där allt ingår för 110 kubiks kittet. För softail står det ju som ovan:
B as in balanced... sitter i softail- standard, fatboy, deluxe, nighttrain och i Deuce
A-motorerna sitter i dynamodellerna och är gummiupphängda.
Kan det ha något med ABS eller drive by wire att göra? eller något annat som deluxen har men som saknas på övriga softails?
På 11:or och nyare alltså...
Senast redigerat av mr.andersson den 2013-03-16 klockan 22:52.
En hoj blir aldrig klar.. det känns bara så ibland.
