Screamin Eagle SE 575 kammar, gått ca 100 mil = nyskick.
Bolt in för sportster 2000 och senare.
Kan monteras i äldre maskiner om man använder piniongear från 2000 eller nyare.
Ger +90hk vid 7000rpm ihop med 11:1 i kompression och portade toppar.
Pris: 1000.-
Mail eller ring vid intresse: 0705-839389 / mobil@fructus.se
NRHS beskriver kammarna så här:
New for 2005 is the SE .575 lift cam set for XL's. Our testing has shown this to be an excellent grind for street performance use, with the potential for the same or more power across the rpm range as compared to the SE 536, but like the SE 536, it's valvetrain dynamics are good enough for an everyday street motor, without the need for excessively high spring pressures and the expensive supporting cast of valvetrain components that goes with it. See our Tech pages for more info
//Micke
Senast redigerat av Turbomicke den 2012-03-24 klockan 08:15.
