1" vad jag får fram, 2007 ändrades den till 25mm
The 2005 - 2006 1" axles (I don't have info on the later models) have a 24 mm X 2 mm pitch thread so the nuts are 24 mm X 2 mm pitch. The flats on the nut are 36 mm apart meaning you need a 36 mm wrench to loosen or tighten them.
