Resultat 1 till 10 av 10
Ämne: Orange bobber
    Orange bobber
    “Evil Or Sacred” uses as main components a Paughco Wishbone rigid frame with a 30-rake, a fully rebuilt 1974 Harley Shovelhead 80″ engine, a RevTech 4-speed tranyy, a narrow 2″ Tech Cycle primary drive, a genuine Harley Springer front end and a pair of 18″ spoke wheels. After basic mockup and driveline alignment, Jack holding 2 DOT welding certifications and a AWS D1.1 D1.5, had no difficulty getting the fabrication job started and correctly done. Tom Feher provided support in making an oil tank from 2 old fire extinguishers that he had laying around his shop, then bent all rigid fuel and oil lines to be later brass plated. Gabe from After Hours Choppers was called to make the gas and oil caps from solid brass. Steve Weinstock from Lillian Rose Choppers chiseled some metal tattoos on the air cleaner. Most of the custom parts have been chosen from vendors belonging to the Limpnickie Lot , a cooperative of Builders (see tech sheet.) Brian O’Hara of B-Man Stripping applied all pinstriping and gold leaf. (photography copyright Lydia Johnson, Johnson Camera, courtesy to Cyril Huze)
    V.I.B - Vinnare BOTM Feb 2012 ElMilagro.s avatar
    Shitlake.
    438
    Admin levererar igen. Det är ju så här det ska se ut.
    Bobber 883 -06
    Jääääävligt sjysst
    nice
    Vacker som en 17 åring .
    Snyggast hittills
    Man blir ju tårögd....vilken hoj.
    Så ska det se ut!!!!
  1. Bobber bygge
    Av Rolle i forum Custom & Byggen
    Svar: 19
    Senaste inlägg: 2012-01-30, 17:54
  2. skön Bobber/länk
    Av JimmyChopper i forum Harley-Davidson Generellt
    Senaste inlägg: 2011-08-19, 10:47
  3. Rå Rat-BoBBer
    Av Orx i forum Harley-Davidson Bilder & Filmer
    Senaste inlägg: 2011-08-18, 18:46
  4. Bobber frågor
    Av Hagis i forum Custom & Byggen
    Svar: 14
    Senaste inlägg: 2011-03-21, 06:05
Taggar för det här ämnet
