Resultat 1 till 15 av 15
Ämne: Felkoder Sportster, alla årsmodeller.
    Sportster Diagnostic felkoder och hur man får fram dessa!
    Evo Sportsters have a handy built in capability to access the error codes stored in the on- board computer. These are great for diagnosing problems with your Sporty. You can save a bundle by diagnosing common problems yourself and doing a simple DYI fix instead of paying a dealer.
    Note: Crank Shaft position sensors in 04 and up rubber mounts are famous for failing. If you get the dreaded: PO 374 code you need a $30- $60 sensor. It takes a few minutes to change and may cost a few hundred if you bring your bike to the dealer! Just one example of an easy fix that can save you major bucks.
    Sportster DTC Instructions/codes 2000-2004
    Enter diagnostic area by turning the ignition from OFF to ON while holding the reset switch in. The normal power-up sequence will occur before entering the diagnostic mode. Diagnostic codes set during this power-up sequence will be stored as well.
    Important Note: Be sure no diagnostic codes are indicated before reset is held in for more than 5 seconds or diagnostic information will be lost.
    When in diagnostic mode the odometer will display the first diagnostic code. When the trip switch is pressed again the next code will be shown. If the trip switch is pressed for more than 5 seconds at any time while in the diagnostic mode, the diagnostic code displayed will be erased.
    There are 7 different diagnostic codes available. They are as follows:
    d01 - Speed sensor power output shorted low
    d02 - Speed sensor power output shorted high or open
    d03 - Not Used
    d04 - Not Used
    d05 - Speed sensor return shorted high
    d06 - Speed sensor return shorted low
    d07 - Not Used
    d08 - Speedometer power over voltage
    d09 - Speed output shorted high
    d10 - Speed output shorted low or open
    CAL XX - Speedometer application calibration number:
    14 = Domestic
    15 = HDI
    When in the diagnostic mode, all codes are displayed in sequence from d01 to d10.
    As a code appears in the display (for instance d02), it will read "d02Set" if set or "d02CLr" if clear.
    The diagnostic mode is exited either by turning ignition from ON to OFF to ON again without depressing the reset switch or if a speed signal greater than 5 MPH is detected.
    Diagnostics cannot be performed if system voltage is less than 9 VDC or greater than 16 VDC. The only exception is d08 which is set when system voltage is greater than 16 VDC.
    After all the diagnostic codes are displayed, the speedometer calibration number is displayed (CAL 14 for example).
    Sportster 2005-2008
    1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
    2- Push odometer reset button in & hold.
    3- Turn ignition switch to Ignition and release odometer reset button. Background lighting will illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
    4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
    5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
    P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carburetor])
    S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
    SP = speedometer
    T = tachometer
    6 - To get the DTC in an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
    7 - Record the codes.
    8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed. NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
    9 – Press and release the odometer reset button to continue to the next module.
    10 – Turn Ignition switch to OFF.
    On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
    "No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
    Priority/DTC/Fault condition
    HFSM = Hands Free Security Module
    TSSM = Turn Signal Security Module
    TSM = Turn signal module
    B0563 Battery Voltage High TSM/TSSM
    B1004 Fuel Level Sending Unit Low Instruments
    B1005 Fuel Level Sending Unit High/Open Instruments
    B1006 Accessory Line Overvoltage Instruments
    B1007 Ignition Line Overvoltage Instruments
    B1008 Reset Switch Closed Instruments
    B1121 (TSM) Left Turn Output Fault - (HFSM) Left Turn Output Open
    B1122 (TSM) Right Turn Output Fault - (HFSM) Right Turn Output Open
    B1123 (HFSM) Left Turn Output Short to Ground
    B1124 (HFSM) Right Turn Output Short to Ground
    B1125 (HFSM) Left Turn Output Short to Battery
    B1126 (HFSM) Right Turn Output Short to Battery
    B1131 (HFSM) Alarm Output Low
    B1131 Alarm Output Low TSM/TSSM
    B1132 (HFSM) Alarm Output High
    B1132 Alarm Output High TSM/TSSM
    B1134 Starter Output High TSM/TSSM
    B1135 Accelerometer Fault TSM/TSSM
    B1136 (HFSM) Accelerometer Tip Test Error
    B1141 (TSM) Ignition Switch Low/Open - (HFSM) Ignition Switch Low/Open
    B1142 Smart Security System Internal Fault
    B1143 (HFSM) Security Antenna Short to Ground
    B1144 (HFSM) Security Antenna Short to Battery
    B1145 (HFSM) Security Antenna Open
    B1151 Bank Angle Sensor(BAS) Short to Ground
    B1151 Sidecar BAS Low TSM/TSSM
    B1152 Bank Angle Sensor(BAS) Short to Battery
    B1152 Sidecar BAS High TSM/TSSM
    B1153 Bank Angle Sensor(BAS) High
    B1153 Sidecar BAS Out of Range TSM/TSSM
    B1154 Clutch Switch Input Short to Ground
    B1155 Neutral Switch Input Short to Battery
    P0106 MAP Sensor Rate of Range Error Carb
    P0107 Map Sensor Failed Open/Low Carb
    P0107 Map Sensor Open/Low EFI
    P0108 Map Sensor Failed High Carb
    P0108 Map Sensor High
    P0108 Map Sensor High EFI
    P0112I AT Sensor Voltage Low EFI
    P0112I AT Voltage Low
    P0113I AT Sensor Voltage Open/High EFI
    P0113I AT Voltage Open/High
    P0117 ET Sensor Low
    P0117 ET Sensor Voltage Low EFI
    P0118 ET Sensor High
    P0118 ET Sensor Voltage Open/High EFI
    P0120 TPS1 Range Error
    P0122 TP Sensor Open/Low EFI
    P0122 TPS1 Low
    P0123 TP Sensor High EFI
    P0123 TPS2 High/Open
    P0131 Front Oxygen Sensor Low
    P0132 Front Oxygen Sensor High
    P0134 Front Oxygen Sensor Inactive
    P0151 Rear Oxygen Sensor Low
    P0152 Rear Oxygen Sensor High
    P0154 Rear Oxygen Sensor Inactive
    P0220 TPS2 Range Error
    P0222 TPS2 Low
    P0223 TPS2 High/Open
    P0261 Front Injector Open/Low
    P0262 Front Injector High EFI
    P0263 Rear Injector Open/Low EFI
    P0264 Rear Injector High EFI
    P0371 Crank Position Sensor (CKP)
    P0372 Crank Position Sensor (CKP)
    P0373 CKP Sensor Intermittent
    P0374 CKP Sensor Not Detected Carb
    P0374 CKP Sensor Synch Error EFI
    P0444 Purge Solenoid Open/Low
    P0445 Purge Solenoid High
    P0501 VSS Sensor Low
    P0502 VSS High/Open
    P0505 Loss of Idle Sped Control EFI
    P0562 Battery Voltage Low
    P0563 Battery Voltage High
    P0572 Brake Switch Low
    P0577 Cruise Control Input High
    P0602 Calibration Memory Error Carb
    P0603 ECM EEPROM Memory Error
    P0603 EEPROM Failure Carb
    P0604 RAM Failure Carb
    P0605 ECM Flash Error EFI
    P0605 ECM FLASH Memory Error
    P0605 Program Memory Error Carb
    P0607 Converter Error Carb
    P06415 V+Vref 1 Out Of Range
    P06515 V+Vref 2 Out Of Range
    P1001 System Relay Coil Open/Low
    P1002 System Relay Coil High/Shorted
    P1003 System relay contacts open
    P1004 System Relay Contacts Closed
    P1009 Incorrect Password
    P1010 Missing Password
    P1270 TGS Validation Error
    P1351 Front Ignition Coil Driver Open/Low
    P1352 Front Ignition Coil Driver High/Shorted
    P1353 Front Cylinder No Combustion
    P1354 Rear Ignition Coil Driver Open/Low
    P1355 Rear Ignition Coil Driver High/Shorted
    P1356 Rear Cylinder No Combustion
    P1357 Front Cylinder Combustion Intermittent
    P1358 Rear Cylinder Combustion Intermittent
    P1475 Exhaust Actuation Position Error
    P1477 Exhaust Actuator Open/Low
    P1478 Exhaust Actuator Shorted/High
    P1501 Jiffy Stand Sensor Low
    P1502 Jiffy Stand Sensor High
    P1510 EFI Limited Performance Mode
    P1511 EFI Power Management Mode
    P1512 EFI Forced Idle Mode
    P1514 Air Flow Fault
    P1600 EFI Module Processor Internal Error
    P2100 EFI Motor Circuit Open
    P2101 EFI Motor Circuit Range Performance (Actuation Error)
    P2102 EFI Motor Circuit Low
    P2103 EFI Motor Circuit High
    P2105 EFI Forced engine shutdown
    P2107 EFI Module Processor Internal Fault
    P2119 EFI Motor Throttle Body Range Performance
    P2122 TGS1 Low/Open
    P2123 TGS1 High
    P2127 TGS2 Low/Open
    P2128 TGS2 High
    P2135 TPS Correlation Error
    P2138 TGS Correlation Error (Twist grip sensor)
    P2176 EFI Closed Position Not Learned
    U1016 Loss of ECM Vehicle Speed, Vehicle Inhibit Motion or Powertrain Security Status TSM/TSSM
    U1016 Loss of ICM/ECM Serial Data Instruments
    U1064 Loss of TSM/FSFM Serial Data to ICM / ECM
    U1064 Loss of TSM/TSSM Serial Data Instruments
    U1097 Loss of Speedometer Serial data Carb
    U1097 Loss of Speedometer Serial data EFI
    U1097 Loss of Speedometer Serial Data to ECM
    U1097 Loss of Speedometer Serial data TSM/TSSM
    U1255 Missing Message at Speedometer EFI
    U1255 Serial Data Error
    U1255 Serial Data Error/Missing Message EFI
    U1255 Serial Data Error/Missing Message Instruments
    U1255 Serial Data Error/Missing Message TSM/TSSM
    U1300 ECM Serial Data Low
    U1300 Serial Data Low
    U1300 Serial Data Low Instruments
    U1300 Serial Data Low TSM/TSSM
    U1301 Serial Data Open/High Carb
    U1301 Serial Data Open/High EFI
    U1301 Serial Data Open/High Instruments
    U1301 Serial Data Open/High TSM/TSSM
    ----------------------- AFR – Air Fuel Ratio
    ATS – Air Temperature Sensor
    BAS – Bank Angle Sensor
    CCM – Cruise Control Module
    2/9/2010 I updated the codes and put them in alphabetical order.
    Don
    A handy hint: On occasion relays have a bad connection due to corrosion. Dielectric grease is your friend Stuck on the road and can't find a Harley dealer? Duralast PN 19997 41-5154 or Napa PN ECH#AR614 are supposed to be replacements.
    Web masters are welcome to link to this guide.
    V.I.B 883rs avatar
    Mar 2012
    Söder om söder
    204
    Det verkar vara lite bökigt det där, åtminstone på nyare modeller, någon som provat?
    Citat Ursprungligen postat av 883r Visa inlägg
    Vänta tills imorgon, jag ska översätta hur man ska göra, lite enklare.
    V.I.B 883rs avatar
    Mar 2012
    Söder om söder
    204
    Kungligt!
    Du ska ju inte behöva åka långväga till en verkstad och betala massa pengar när du kan göra det själv på 5 minuter
    En svensk variant för 2005-2008 (ev även nyare, ni får testa)
    1. Stäng av tändningen med nyckeln och se till att "dödarknappen" är i ON/PÅ-läge.
    2. Tryck in trippelmätarknappen och håll den inne.
    3. Vrid om nyckel till läge "Ignition" och släpp trippelmätarknappen. Bakgrundsbelysningen ska tändas och hastighetsmätaren ska gå upp på fullt och alla varningslampor kommer tändas. Order "DIAG" ska komma upp på displayen.
    4. Tryck in trippelmätarknappen en gång och du ska se bokstäverna "PSSPt" på displayen, där P kommer att blinka.
    5. Varje bokstav i "PSSPt" representerar en diagnostiksektion, den som blinkar är den som ska kollas. För att flytta bokstav, tryck på trippelmätarknappen för att flytta till annan sektion. Sektionerna är:
    P = ECM/ICM (Electroniska Kontrol Modulen [EFI/Insprut] / Tändnings Kontrol Modulen [Förgasare])
    S = TSM/TSSM (Blinkers / Blinkers larm-modul)
    SP = Hastighetsmätaren
    T = Varvräknaren (om det finns en)
    6. För att få fram en felkod, i sektionen du vill kolla, håll inne trippelknappen i 5 sekunder och släpp. OM det är nåt fel, kommer denna koden upp om INTE kommer det stå "NONE". Gå igenom alla sektioner likadant genom att flytta med trippelmätarknappen.
    7. Notera ev felkoder och kolla i listan ovan.
    8. När du är klar, stäng av tändningen med nyckeln.
    Lycka till!
  7. Följande användare tackar admin för detta inlägg:
    Johanna_HD (2024-03-02)
  8. #7
    Hoppsan! Det var många finesser på ett järnspett, rena rama raketforskningen att ha en ny Harley i dessa dagar
    Väldigt bra info och pedagogiskt förklarat så man fattar även om man inte ha det framför sig
  9. #8
    V.I.B 883rs avatar
    Mar 2012
    Söder om söder
    204
    Tack för hjälpen Admin, har kollat nu och den visar felkod "P0505 Loss of Idle Sped Control EFI", någon som vet vad det innebär och hur jag åtgärdar det?
  10. #9
    Kan tydlig vara lite olika saker.
    Here's a summary from the Diagnostic Manual:
    P0505 - Loss of idle speed control
    Loss of idle speed control will result if the idle RPM is +-200 from preset idle speed and IAC motor is at zero or maximum for greater than 5 seconds.
    - Loss of idle speed control is not an indicator that the IAC is bad. Other causes are intake leaks, misfiring cylinder.
    - Leaking injectors could cause poor idle. To check for leaky injectors remove A/C, turn throttle wide open, turn key to ON for 2 seconds and then off for 2 seconds five consecutive times. Replace injectors if there is any evidence of raw fuel in the bores.
    - Vacuum leaks
    - Contaminated fuel
    - Excessive Oil in crankcase
    - TP sensor reading greater than 1 % (cable misadjusted), battery less then 9 Volts, orvehicle speed sensor (VSS) greater than 0 will disable idle speed control.
    - Loss of battery power to terminal 31 of ECM.
    This should give you a lot of things to look for. Also if the ECM loses power, the ECM will assume that the vehicle is stopped and adjust the idle air control to bring the idle up and set a code too.
    It could be as simple as an air leak around the intake. Try using the WD40 trick to see if you are leaking air first....the most basic test, and work your way from there, to checking all the harness connections. Check all the other things on the list it may be if those dont come up with something. MAKE SURE YOUR BATTERY IS GOOD...less tha 9vdc will disable the idle speed control.
    En till.
    Speedometer Signal and Code P0505
    The speedometer signal is an extremely important input for the Delphi fuel
    injection system. The ECM monitors throttle position and speed signal inputs in
    order to properly maintain the set idle speed. If the ECM loses the speed signal
    for any reason while the throttle is closed, the ECM assumes the vehicle is
    stopped and will adjust the idle air control counts to bring engine rpm to the set
    idle speed. This could set a P0505 code and adversely affect engine idle.
  11. #10
    V.I.B 883rs avatar
    Mar 2012
    Söder om söder
    204
    Det var ju lite att kolla, ska väl börja med att kolla batteriet och om den tar tjyvluft, den lampan började lysa efter en tur i stan med en polare bakpå och jag fastna vi varenda rödlyse så det blev 1-2-1-2-1 på växeln hela tiden så jag trodde den var överhettad, jag såg att lampan tändes i en högerkurva i låg hastighet.
    De omständigheterna tyder väl på att det kan nått som har skakad loss så den börjar sno extraluft?
  12. #11
    Googla på: P0505 - Loss of idle speed control , massor av träffar! Du kanske hittar mer matbyttigt.
  13. #12
    V.I.B 883rs avatar
    Mar 2012
    Söder om söder
    204
    Tips till er alla, gör inte som jag.
    Dum som jag var så tänkte jag inte på att man måste nollställa felkoden när man åtgärdat det, säkringen för ECM satt löst så jag pillade dit den igen men fortsatte ju varna så jag mecka vidare ett jävla tag eftersom lampan fortsatte varna.
    Det steg som Admin missade att översätta är följande.
    Har inte testat det än då det är en bit till garaget men jag ska testa i morgon el nått så.
  14. #13
    Sorry 883r, missade den. Så du har löst det alltså, det var säkringen som satt löst? Skitbra isåfall.
  15. #14
    V.I.B 883rs avatar
    Mar 2012
    Söder om söder
    204
    Har inte kollat än, men det stod ju nått om att den kunde varna för det om ECM inte fick nå kräm, vilket den inte får om säkringen inte sitter i, så jag hoppas att det är det som är felet, ska försöka nollställa datorn i morgon el övermorgon och se om det reder sig.
  16. #15
    Jun 2016
    Tjörn
    3
    Funkar detta på min Iron årsmodell -12 tro? Den slutar ladda efter ett tags körning.
  1. Hej alla!
    Av Båging i forum Ny på harleyforum.se?
    Svar: 102
    Senaste inlägg: 2016-07-06, 13:30
  2. Hej alla!!
    Av dynababe i forum Ny på harleyforum.se?
    Senaste inlägg: 2011-07-04, 01:15
  3. Hej alla nya
    Av Hagis i forum Ny på harleyforum.se?
    Senaste inlägg: 2011-06-02, 10:44
  4. Skål alla!
    Av robbbull i forum Off Topic
    Senaste inlägg: 2011-04-03, 11:37
  5. Felkoder Dyna 06->
    Av adHD i forum Harley-Davidson Dyna
    Senaste inlägg: 2011-02-24, 21:58
