Ingen ojla på "pappers filter".
Vissa filter, ex Harley Original SE vill inte att man oljar inte filtren, andra tillverkare vill att man gör detta.
Är inte oljan på filtret för att skiten ska fastna i den? Eller är jag helt fel ute?
Och baserat på om ovan är rätt, kan man trots detta olja in de filter som INTE ska oljas in....
Hur rengör man skrikande örnens filter bäst då? Luft och lite buller? Hur ofta ?
Läser att pappersfilter kan du tvätta, YES diskmedel & ljummet vatten, sen låta lufttorka....OM det är tvättbart, kan stå på filtrets metallhölje.
My SE air cleaner is washable for my 08. I washed it with dish soap and warm water then rinsed it out, then used KN cleaner and rinsed again, then let air dry. The KN cleaner did get more dirt out of it. No oil!
Saxat fråm HDs manual SE Airfilter.
MAINTENANCE
Air Cleaner Element Maintenance
NOTES
This is a dry air filter. Do not apply oil to the filter element.
When servicing the air cleaner, apply Loctite 243 (blue) to
threads of all fasteners.
1. See Figure 1. Remove air cleaner cover (B) and inspect
the filter element (7) every 5000 mi (8000 km), or more
often under dusty conditions.
2. Clean filter element as follows:
a. Remove and wash element by immersing it, on edge,
in a shallow pan containing enough Air
Cleaner/Degreaser to cover no more than 3/4 the
depth of the filter pleats. Do not let dirty solution get
inside the element. Carefully "roll" the element in the
solution around its perimeter until the entire outer
surface of the filter pleats has been soaked.
b. Remove filter element from cleaner/degreaser and
allow five minutes for the cleaner to dissolve the dirt.
c. From the inside out, rinse the element with cold water.
Shake off excess water, and allow the element to air
dry. Do not dry with compressed air.
3. Install air cleaner element and cover
Hela PDF:en här
http://www.harley-davidson.com/en_US...ts/-J04346.pdf
JA, de va bra jobbat, tack.
