Resultat 1 till 7 av 7
Ämne: Luftfilter, olja eller inte?
    Question Luftfilter, olja eller inte?
    Vissa filter, ex Harley Original SE vill inte att man oljar inte filtren, andra tillverkare vill att man gör detta.
    Är inte oljan på filtret för att skiten ska fastna i den? Eller är jag helt fel ute?
    Och baserat på om ovan är rätt, kan man trots detta olja in de filter som INTE ska oljas in....
    Ingen ojla på "pappers filter".
    V.I.B indy 500s avatar
    Ödesböle Jämtland
    570
    Cool
    Hur rengör man skrikande örnens filter bäst då? Luft och lite buller? Hur ofta ?
    Läser att pappersfilter kan du tvätta, YES diskmedel & ljummet vatten, sen låta lufttorka....OM det är tvättbart, kan stå på filtrets metallhölje.
    My SE air cleaner is washable for my 08. I washed it with dish soap and warm water then rinsed it out, then used KN cleaner and rinsed again, then let air dry. The KN cleaner did get more dirt out of it. No oil!
    Saxat fråm HDs manual SE Airfilter.
    MAINTENANCE
    Air Cleaner Element Maintenance
    NOTES
    This is a dry air filter. Do not apply oil to the filter element.
    When servicing the air cleaner, apply Loctite 243 (blue) to
    threads of all fasteners.
    1. See Figure 1. Remove air cleaner cover (B) and inspect
    the filter element (7) every 5000 mi (8000 km), or more
    often under dusty conditions.
    2. Clean filter element as follows:
    a. Remove and wash element by immersing it, on edge,
    in a shallow pan containing enough Air
    Cleaner/Degreaser to cover no more than 3/4 the
    depth of the filter pleats. Do not let dirty solution get
    inside the element. Carefully "roll" the element in the
    solution around its perimeter until the entire outer
    surface of the filter pleats has been soaked.
    b. Remove filter element from cleaner/degreaser and
    allow five minutes for the cleaner to dissolve the dirt.
    c. From the inside out, rinse the element with cold water.
    Shake off excess water, and allow the element to air
    dry. Do not dry with compressed air.
    3. Install air cleaner element and cover
    Hela PDF:en här
    http://www.harley-davidson.com/en_US...ts/-J04346.pdf
    Ödesböle Jämtland
    570
    JA, de va bra jobbat, tack.
    jo, men käringen vansinnig.. jag sitter ju här jämt säger hon...
  1. SBM eller inte SBM
    Av Hagis i forum Off Topic
    Svar: 122
    Senaste inlägg: 2013-11-12, 21:06
  2. Sons of Anarchy - Bra eller inte?
    Svar: 63
    Senaste inlägg: 2013-01-04, 17:31
  3. Luftfilter
    Av belsebub36 i forum Motor, Luft, Buller ,Ventiler, Kammar, Förgasare
    Svar: 10
    Senaste inlägg: 2012-08-11, 11:50
  4. Mer olja
    Av Tundra Trotter i forum Oljor, Bensin, Vätskor
    Svar: 26
    Senaste inlägg: 2011-12-30, 18:48
  5. Luftburk/luftfilter
    Av tolfan i forum Harley-Davidson Softail
    Svar: 13
    Senaste inlägg: 2011-05-07, 00:24
Taggar för det här ämnet
