..och andra insprutare. Läste att tömma en tank på en EFI H-D kräver att man gör detta via crossover-slangen som länkar ihop halvorna.
Detta kräver att man klipper slangen och skaffar nya delar, någon som har ett annat tips för denna operation?
Via "soppakranen" går inte om jag fattat det rätt.
It is pretty simple to do it. First you will need a gas can that is big enough to hold the gas that is in your tank, ie two gallons of gas will not fit in a one gallon can. Get two pairs of vise grips or something that will clamp down on the cross over line at each end but be careful not to clamp down on the metal tank lines as you do not want to crush them. Cut the line near one of the vise grips or whatever clamping method you have used and place the fuel line in the gas can. Open the vise grip and drain the tank. Replace the fuel line and clamps during reassembly. You can pick up a new fuel line and hose clamps at any automotive store for a couple of bucks. You can also use a siphon to drain the tank and then remove the crossover line by cutting the clamps which will have to be replaced during reassembly. Both methods will work it just depends on which one you feel comfortable with. I have heard of a few other ways to do it as well such as using caps once the line is removed but that could get a little messy.
